Computer wizard nerd required...
spark240spark240 Frets: 2092
Im using a Mac, can I do some sort of Hot key trickery so I can press one button to insert a website address into a post?
I want to be able to insert our Bandcamp link quickly in posts.
Ta.
Mac Mini M1
Presonus Studio One V5
 https://twitter.com/spark240
Reddit r/newmusicreview
  • Guitar_SlingerGuitar_Slinger Frets: 1489
    edited July 2017
    Command+W ?
  • FunkfingersFunkfingers Frets: 14578
    Copy/Paste [Command C, Command V].
    Command+W ?
    Nope. In Mac OS, that shortcut is reserved for Close Window.
  • Axe_meisterAxe_meister Frets: 4659
    get flycut so you can just do shift+cmd+v and then left/right arrows to scroll through all the different saved texts you may want to paste
  • wibblewibble Frets: 1111
    If you don't want to copy and paste all the time then you can take advantage of the MacOS built in text substitution function.
    Go to system preferences | keyboard | text
    click on + to add a new substitution eg mbc (replace)  http://you.link.to.spam (with)
    now every time you type mbc in an app that supports substitution, a little pop up with your substitution text will appear for you to immediately select (via click or by hitting space/tab).
    Unfortunately, if you want to use this in a web browser then only Safari supports this. Also some javascript editors can interfere with this behaviour on some forums/forms.
  • MyrandaMyranda Frets: 2940
    If you're in a browser like Chrome F6 should even select the address bar if you're really wanting keyboard-short-cut-madness ...
  • Command+W ?
    You've sunk my funnyship. :)
  • stickyfiddlestickyfiddle Frets: 27248
    Cmd+L selects the address bar. Apple F-keys all have other functions by default.
