EHX B9 organ pedal - anyone got experience using one?
KickTheHabitKickTheHabit Frets: 93
considering as some the soul numbers we do might sound even better with some authentic organ sounds...
anyone got experience ( good or bad ) with one of these?
  • merlinmerlin Frets: 6720
    They work well, but you need to use different techniques. Regular strumming and picking don't work.
    I bought one but never use it if you wanna buy it!
    Oh, on a fairly recent gig, the venue couldn't provide a Hammond style keyboard that. We needed, and came up with a clavova. We put it through the EHX B9 and it was perfect.
    Might be up for it if the price was tempting enough!! I might end up doing the same ..
  • monquixotemonquixote Frets: 17663
    Beware!
    Mine was a pain in the arse then broke
  • Beware!
    Ohhhhh!!
  • I had the eqd pedal that does the same thing to an extent and was fun. But not enough to keep
    Instagram is Rocknrollismyescape -
    FOR SALE - Catalinbread Echorec, Sonic Blue classic player strat and a Digitech bad monkey
  • FunkfingersFunkfingers Frets: 14554
    Like a with MIDI Guitar controller, your picking hand techniques need to be tidy to avoid mistriggering.
    I have considered buying the B9 but decided against. Firstly, I prefer the presets of the C9 model. Secondly, much of what I wanted from either of these pedals could be achieved with the EHX Lester G pedal. Its combination of compression, overdrive and rotary cabinet fulfilled the pad sound brief nicely.
  • ZenOvertoneZenOvertone Frets: 234
    Mine has a noticeable volume boost when engaged but ok if you stick to triads and try and emulate organ comping stuff...
  • vasselmeyervasselmeyer Frets: 3674
    I bought one, played with it for a bit and then moved it on as I knew I'd never really use it apart from  a couple of songs. It's pretty convincing in a band mix though. If I recall, there was something odd about the switching and wet/dry mix.
    I would say, worth a punt second hand.
  • blobbblobb Frets: 3001
    Feelin' Reelin' & Squeelin'
