Need to drill a countersunk hole in a pickguard
I'm not very handy - can someone please tell me what kind of countersinking tool I will need and what size?  It's the small hole near the neck, the large hole for the bracket is pre-drilled.
I am attempting to posh-up my LP Studio
Thanks
    Use an oversized (newish) wood drill bit, and do it by hand (not drill) - or just get a countersink bit.
    Feedback
  • robertyroberty Frets: 10893
    @Jalapeno thanks, will any countersink bit do?  Or I can just bore it out with a normal bit by hand?
  • octatonicoctatonic Frets: 33819
    edited July 2017
    I use this:
    http://www.leevalley.com/en/Wood/page.aspx?p=41012&cat=1,180,42240,42281&ap=1
    I use a pillar drill with a depth stop though.
    There aren't really any variations other than circumference - all screw heads are the same angle (more or less).
    I use a wood drill by hand (wouldn't for metal obvs)
    Feedback
  • ICBMICBM Frets: 72514
    edited July 2017
    You want a hand countersink tool. They're very hand for quite a lot of jobs (especially quickly and easily taking burrs off drilled holes), and not expensive.
    Like this -
    https://www.amazon.co.uk/CONNEX-COX972250-12mm-Hand-Counter/dp/B00BZH4CDI/ref=sr_1_3?ie=UTF8&qid=1501415230&sr=8-3&keywords=hand+countersink
    You need to drill the screw hole through first though, with a normal twist drill bit - the countersink doesn't go all the way down on a small hole like this.
  • RockerRocker Frets: 4989
    I countersink holes in plastic by using a large drill and twist it by hand, between my forefinger and thumb.  A few spins is usually enough....
    Nil Satis Nisi Optimum
    Cheers thanks all, hopefully I won't cock it up!
    Practice on a piece of scrap first.
  • FelineGuitarsFelineGuitars Frets: 11619
    Get a countersink - they are cheap enough and they do come in handy now and then.
    Or just walk in somewhere friendly (like Feline Guitars) and have them drill the hole and countersink it too
    If it's real quick we'd probably only ask for £5
  • OilCityPickupsOilCityPickups Frets: 10582
    Make sure you countersink deep enough ... I see this fault a lot: the screw head sitting proud of the countersinking and showing an ugly gap at the edges of the screw head. Try on a piece of scrap before hand, then use a drill press and depth stop to get it bang on right. 'Right' is usually a little deeper than you think it will be.
    Finally got around to this - used a hand countersink, few good twists, worked a treat.  Thanks for the advice
    What do you guys think?  Was channeling the look of a Les Paul Special, specifically this one.  I wanted a 50's neck though, and the Special Plus has a slim profile.  Picked up this virtually unplayed 2004 Studio for cheap on eBay and swapped all the gold out.  The pups are JB/Jazz.  It weighs a metric tonne and sings for days
