Storing an amp in a garage?
mrleon83mrleon83 Frets: 205
So, I've sold my house to go traveling , I have a garage which I'm storing stuff in.. would a mesa boogie combo be ok in there?
  • ICBMICBM Frets: 72751
    Maybe… how dry is the garage?
    Even if it does appear completely dry you will often get rust on the metalwork and other problems though. If you're just putting it into storage and don't need to get it out for a long time probably the best thing to do is wrap it in plastic sheeting and tape it up thoroughly to make sure it's airtight - do this somewhere warm and dry so you're not trapping any moisture inside.
  • DJH83004DJH83004 Frets: 196
    Can you leave it with family or friends? as IC says despite your best efforts, if it is left in a garage, where there are temperature swings, something (usually the transformer laminations are first), will start to rust.
  • mrleon83mrleon83 Frets: 205
    Garage is very dry, it has recently been returned so should be ok? I'll wrap it in cling film and hope for the best , cheers !
  • 57Deluxe57Deluxe Frets: 7348
    So, you want it covered is indelible spider droppings; sodden and damp and maybe used as a rats nest??
    <Vintage BOSS Upgrades>
  • simonksimonk Frets: 1467
    Do what @ICBM says above but also pop a couple of those sachets of silica that you get with almost everything inside.
    Good suggestion.. or maybe I should just sell it?
  • Make sure its in a case or something as it can get damp, and the moisture can damage the electrics.
  • Best option buy a decent flight case
    www.maltingsaudio.co.uk
  • NeilNeil Frets: 3659
    Sell it if you are going for a good long while.
