Helix Native
  • PolarityManPolarityMan Frets: 7300
    If I do I'll have to live with only 1 tweeter between a set of monitors for longer than I'd really like :)
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • octatonicoctatonic Frets: 33837
    First irritation- you can't resize the plugin window.
    They need to fix that for those of us with 5k displays.
  • nick79nick79 Frets: 257
    nick79 said:
    nick79 said:
    Guys can anyone help me, i'm struggling with Reaper... I can't play anything 'live' through Native, if i import a track in that plays no problem, but if i play guitar into it nothing.. I've got input signal in the track mixer, but nothing in the master. Do i need to arm it somehow?
    Yes - the round red button on the track arms it. You also have to enable the monitoring too - here are the two buttons you need:
    Thank you. I've now got the input in helix showing signal, but still no modelled sounds? Only i could struggle this much with something..
    On your interface (what is it, by the way?), you should have a "mix" control - it should have "input" at one end and "computer" at the other. You want it all the way to "computer".
    By the way, you have clicked the non-red button highlighted above, haven't you? That's the one that tells it to send your processed signal out to the speakers.
    Finally sorted now, thanks mate. Just spent an hour playing through it and i'm impressed, need a bit of time to play around tweaking but so far so good.
  • duotoneduotone Frets: 995
    Argh that's a pain
  • sweepysweepy Frets: 4200
    I run a 43" 4K TV as a monitor for my Mac and it is a little cramped, display wise,a re-scaleable window would be a neat touch
    If I recall correctly @Digital_Igloo did say that scalability was something they had on the cards after the 1.0 release.
  • TimmyOTimmyO Frets: 7551
    Argh that's a pain
    It's on road map - first patch will.be to.add snapshots and tuner iirc
    Red ones are better.
  • mrkbmrkb Frets: 6915
    I'm running it in a VST host called Cantible to reduce the CPU overhead. Seem to run Ok on my 6 year old laptop. What are other PC users running it in?
    Karma......
    Ebay mark7777_1
  • mrleon83mrleon83 Frets: 191
    Im using it on a 2015 MacBook Pro, 16gb ram , ssd no probs here but I'm going to try it on a project today ... see how tough it is on resources ...
  • dindudedindude Frets: 8540
    I'm def going to try the free trial when I get a period where I can maximise the 15 days usage. May just turn this sceptic into a believer!
    TimmyO said:
    Argh that's a pain
    It's  feature lite ... no tuner, although I usually have a pedal before my guitar goes into the soundcard.
    I haven't delved that deep but does Helix have any rack units?
    For those with legacy Line 6 devices it seems Line 6 are being lenient on the four device rule and have just upped me to 5 so I can run Helix - you have to request this via a support ticket.
  • digitalscreamdigitalscream Frets: 26742
    Could be worth putting it on their IdeaScale site as a suggestion.
    <space for hire>
  • RandallFlaggRandallFlagg Frets: 13958
    Any reports on sound? or A/B comparison to the hardware Helix plugged into same monitors/set-up?
    They're nigh on the same.
  • robinbowesrobinbowes Frets: 3054
    What do you mean?
    R.
    edited August 2017
    Fretwired said:
    TimmyO said:
    Argh that's a pain
    Yes they have Helix Rack:
    https://www.andertons.co.uk/p/GHELIXRACKUK/multi-fx-units/line-6-helix-rackmount-multi-effects-unit
    What do you mean?
    R.
    I use Amplitube quite a lot and it offers an FX loop for stomp boxes and a rack at then end of the chain with a bunch of useful rack units, such a two channel stereo EQ, delay, reverb etc. Just wondered if Helix had such a thing?
    Ah, I see.
    No, it doesn't. But you can do that within the DAW, ie. add post-Helix effects.
    R.
    It is early days- it will come.
    At least they got the modelling right.
    I use TC Electronic's Polytune plugin instantiated before the Helix.
