PolyTune plugin on sale - Helix Native owners take note
    edited August 2017
    Will be grabbing dat by the poosay
    The inbuilt ones in Cubase and logic are perfectly sufficient for me
    I don't like the Logic one, it's not as quick to track low notes as my Axe FX tuner or TU3.
    I have Cubase 9 Pro and the tuner isn't 100% accurate ..
    I'm not 100% accurate either ;)
    Neither am I ... my old Strat is a bugger to tune .. sounds ace though.
  • So why do you need a tuner in a DAW? Not being an arse, just not a big recorderer so thought you would just tune before recording?
    It is useful when you're recording DI, with plugin amp sims.
    Ideally you check your tuning before every take, so if it's as good as the pedal then it's totally worth buying at $9.99 as it'll get used a lot
    This.
    If I'm recording I tend to leave my guitar plugged into my audio interface .. I have an ear for an out of tune guitar so I frequently check and retune.
  • HeartfeltdawnHeartfeltdawn Frets: 22252
    If you want to save the money, use GTune instead.
    http://www.gvst.co.uk/gtune.htm
