Trading feedback | FS: Benson Stonk Box
JM build | Pedalboard plans
Currently, the overdrive part of the signal chain is:
ARC Soothsayer -> VS-XO Drive 1 -> Snouse BlackBox 2 -> VS-XO Drive 2 -> RambleFX Marvel Drive 2
Just asking because if it was - for example - a Fulltone OCD, you need a high-impedance pedal. The OCD has no output buffer and so suffers from tone suck when running into a low impedance (or a long cable).
I assume they're all true bypass? If so then you still need a high-impedance volume pedal (or a buffer), since when they're all off the guitar will be connected to the volume pedal.
ARC Soothsayer == tweaked RAT
VS-XO Drive 1 =~ 808
Snouse BlackBox 2 == tweaked BluesBreaker
VS-XO Drive 2 =~ ODR-1
RambleFX Marvel Drive == MIAB
All TB, except for the VS-XO which as I said has switchable buffers on both sides.
