suggestions please for a creamy smooth overdrive for one of these?
my gunshot is kinda too middy for it and sounds a bit boxy for my ears. the boss SD1 sounds sort of ok when I give the higher gain channels a kick with it as all the harmonics come pouring out.
I've not had one of these style amps before and I'm just trying to tweak stuff to fit. It might be that my ears are thinking of getting a sort of us/boogie ish lead sound out of it sometimes
The OCD into it doesn't sound right to me either - but maybe I'm just a twat and need my ears examaning
I'm also trying to identify stuff to sell so I can go buy either a prs or an eggle (that's the subtext and has been the subject of previous posts!
Personally, I'd think something of that callibre is going to be the way to go - what is it about the SD-1 that doesn't make you go "This is it?" Might the slightly smoother TS-9 do the job?
I think the subtleties of more expensive overdrives with their tweaks and improvements and touch sensitivity, dynamics or whatever, while not to be sneered at, are largely going to be lost when you're kicking an amp that's already driving itself.
Bandcamp
Spotify, Apple et al
The MXT GT-OD is also well worth a look, a bit Tubescreamer-y, but different. A very good lead boost.
For higher gain, the Boss DS-1 works really well with Marshall and similar amps.
The MXR Distortion3 also works really well with these amps.
All these pedals are the gain/tone(mids)/volume type, any pedal with these controls will be worth trying (IE anything along the Tubescreamer lines). Personally I wouldn't bother with anything laid out like a preamp (IE Volume, bass/mid/treble, gain controls) although they can be, and are, very useful in other situations.
If you're going for a Marshall sound are you setting the ISF to the left, not the right?
To be fair, I've got a S1-45 to work on this week and it does seem to sound OK - but also a HT-50 head, which sounds dreadful.
i'm doing a major kit rejig which sadly will involve the sale of some beloved pedals, and a guitar, to buy a new guitar and a couple of pedals for the blackstar
You may be better off getting/using an overdrive with a flatter eq profile.
Effects for Me & my Monkey YouTube channel Facebook Fretboard's "resident pedal supremo" - mgaw
The crunch channel is my favourite on these amps. I used to own the 4 channel EL34
That's a Marshall-in-a-box style pedal, yes? Marshall pedal into a Marshall amp? I don't see the point?
I've now got it fixed, and had a proper listen to it - and it's not anywhere near as good as I thought.
It *is* better voiced than the other Blackstars I'm more familiar with in that it's noticeably brighter and clearer. But the problem is that it's horrifically stiff and hard-sounding - really cutting and brash, not bright in a good 'sparkly' Fender-type way, more like a solid-state amp even though it's mostly valve. And I *like* solid-state amps! I thought my old Peavey had a tendency to be too steely and bright if you're not careful with it, but this Blackstar is worse - and unlike the Peavey, turning the bass up high and the mids low doesn't seem to soften it much.
So my answer to the OP's question is that you're probably going to need a Mesa V-Twin, which is the only pedal I have heard to date which can really give valve-amp-like depth and responsiveness to a hard-sounding solid-state amp, so I expect it would work with this too. Surprisingly, it's much more 'Marshally' than you would expect for a Mesa product. There is a reason for that...
ICBM if time allows could you try driving the Blackstars from the FX return ? I would love to know if the 'stiffness/steeliness ' is in the pre amp or PI/OP stages.
Dave.
