JCM2000 DSL50 - thinking of buying one. Any advice?
13»
  • ICBMICBM Frets: 72572
    jpfamps said:
    I've also seen a few TSLs where a couple of film caps in the pre amp (from memory these are DC blocking caps for the DI out; irony a feature that is probably NEVER used)
    Oh yes it is! In fact, one of the only repairs I've done on one of these which was definitely *not* the amp's fault was one where the owner thought that you could record it silently like that, with no speaker attached :).
    It actually did less damage than most of the ones involving the board arcing when the amp is being run correctly...
  • FWIW I used to own a TSL60 , no issues! I remember in the 2000's gary moore was using a dsl2000 live
