let me know how you get on with it?
Since then used it again - but not gigged - holds it's own - plenty bottom end but no boom - finding I need to put about 4db and some mid boost for solos which feels like more than it should be but using my ears rather than internet advice Only used it as a cab - was interested to see if I could use it on it's own in smaller gigs.
We have a Bose L1 that normally suffices for just vocals but our new drummer is a wee bit louder but bloody good so we have pulled out the big Yamaha PA and I will try that at next rehearsal hopefully. Used it last night in Falkirk (Behind the Wall) and DI'd bass and put in some kick drum too. From vids I saw recorded from the opposite side of the stage from me I was not really audible - going thru the PA should even that up.
much better than a button as you can fade it up and down
hiw did you enjoy behind the wall? I took it off our gig list .. bit too neddy for us
BTW is good upstairs, older crowd and all listened to us so can't complain! Got another booking there too, a Friday which is supposed to be really busy All the young pre-clubbers were downstairs lol
https://www.pmtonline.co.uk/qsc-k10-active-pa-speaker
@Vaiai - how are you getting on with the TS210? Any tips and tricks to get the best out of it? I'll most likely be using it just as a stage monitor for gigs, and for my main output at rehearsals.
Of course, I'm guessing the smart thing would've been to ask that question before buying it, but...never pretended to have much sense.
Certainly loud enough and the bass does need to be tamed a bit - 10" is definitely enough - 12" would be too much!
One thing I did find interesting and need to try it myself was the thread discussing the Fletcher-Munson EQ block:
http://line6.com/support/topic/25978-creating-tones-for-direct-to-foh/
As a stage monitor it's fantastic and much better than monitors I have had in most venues - mainly because you can tweak the sound how you want.
