Car winkers
  • aord43aord43 Frets: 287
    Now that the nights are getting darker, I've noticed something about "daytime running lights". I've seen one or two cars driving in the dark with only daytime running lights on at the front and no lights at the back. Genius! :)
    Yes my 65 plate stupid Merc does this. It's the opposite of what you need IMO. I presume that if I actively put the sidelights on, instead of leaving it on "auto", this will solve things.
    A problem I've found is that my 2016 Merc has automatic lights, and we habitually just leave it on auto all the time.  But in daylight conditions when it has become much more usual these days to have lights on when on the motorway or similar dual carriageway, even in the day, the automatic lights don't come on because it's not dark enough.  I have started manually switching them on, not relying on the auto setting.  Then have to remember to switch back afterwards.
    Interestingly although there are manual settings to turn them on, there is no manual override to turn them off. Which can be annoying if you are sitting parked waiting to pick up kids etc. with the radio on but the car insists on keeping the headlights on until I have pulled the key out.
    I noticed on a trip to the USA that most cars there seem to flash the normal sidelights or tail lights, rather than having dedicated indicator lamps.  That seemed odd but I guess you get used to it.
  • crunchmancrunchman Frets: 11470
    57Deluxe said:
    dunno why they had to change...
    LED much better.  Last a lot longer than a conventional bulb so you don't have to fiddle around changing them.  Will also save a small amount of energy.
  • DominicDominic Frets: 16152
    bring back ye olde hand signals
    This. I give a middle finger to non indicating folk.
    Audi's get a middle finger out of principal.
    For Bmw's I use my words.
    Mercedes, well, after the accident they've caused, I get the pen and paper out and write a stern one to the authorities.
  • ICBMICBM Frets: 72619
    Am I the only one who finds front indicators that are *inboard* of the headlights annoying? It seems to be quite a fashion now - there is no reason for it, since on those cars the sidelight is nearly always outboard of the headlight and they could easily be swapped. I actually thought it was against regulations, but I must be wrong.
    It's quite confusing even when the other headlight is not faulty. When it is it can be downright misleading.
  • I honestly thought this was about folk flirting between cars by means of winking.
    I thought it was a typo :).
  • JezWyndJezWynd Frets: 6115
    This seems beyond stupid. Something that is designed to indicate a basic function such as the proposed direction of travel should be clearly defined in law in terms of positioning, brightness (foot candles?), speed of flash etc. and not subject to fashion.
    /rant
