HELP NEEDED: Rewiring my PRS Santana SE
13»
  • Haha, @professorben I'm 41. I've left it way too long. As I think I said, I hooked up a loom to pickups and that gave a sense of satisfaction so thought I'd do the whole thing...bitten off more than I can chew?
    So, a stripped cables goes from the side across those two tags and ends on the top of the pot with the braided bit? Seems complex...
    Less complex than 3 tiny wires connecting each bit to ground.
    Just strip a bare bit of wire long enough to go across those two switch tags to the side of the pot.
    Then the resistor from the tag to the back of the pot.
    Then your jack socket cable braid connects the pots together.
    Dont forget that wire coming from the bridge goes to ground too.
  • imalrightjackimalrightjack Frets: 3777
    edited September 2017
    I'm sure you've covered everything at least once...
    I'll report back! HUGE thanks!
    Trading feedback info here
    My band, Red For Dissent
  • I'm sure you've covered everything at least once...
    No worries.
    Its easy to describe, less so to physically do.......
  • This sort of malarkey is precisely why I left the Seymour Duncan User Group forum.
    Are you now leaving here?  :#
  • You say, atom bomb. I say, tin of corned beef.
  • This might help, mate, until you learn to ignore posts you don't like:
    https://en.m.wikipedia.org/wiki/Internet_pornography
  • Trading feedback info here
  • Jalapeno said:
    Can't help but feel a couple of photos would aid a diagnosis ......
    Here's one I made earlier. ;)
    https://i.imgur.com/da7l5o0.jpg?1
  • AllAll done, all working - and hats off to the wonderful @professorben - without whom I might have smashed the guitar. I have actually learned a few things, definitely gained confidence and really must proceed to understand the whole thing better (@Funkfingers, those links are useful).
    @TTony - do you have yours setup with 9s/10s/otherwise? This is still setup for 9s and, I think, the stock nut. Considering putting on my usual 10s but don't just now want the faff of changing it. Good call on the IGs. The Tesla Sharks are spot on.
  • I have actually learned a few things, definitely gained confidence and really must proceed to understand the whole thing better.
    <approve emoticon>
    If you if had to re-write this Discussion, you could probably create a better description of the original problem. Confidence and understanding would leave you less angry and frustrated. Photographs usually minimise misunderstandings and save a whole bunch of typing. You might even feel able to remotely diagnose a similar issue for somebody else.
    It is often difficult to decide how to pitch a written reply to questions of this sort. Treating a stranger like a novice may come across as patronising. Assuming full knowledge may confuse the person seeking assistance. Every case is different.
    The best thing about this Discussion is that you have shown respect to professorben for his input.
    The problem at SDUGF was that the forum became inundated with new recruits from Fæcesbook. These numpties had been led to believe the friendly forum regulars would happily provide the sort of aftersales assistance that SD company staff could not be arsed to provide ... and give up their time for free.
    Young people today do not value anything that can be obtained for free. They not only take the assistance for granted, they seem to believe that they are ENTITLED to it.
    For supporting evidence of my assertions, check out the SDUGF Bassment forum zone. Since mid-2016, almost all awkward bass wiring questions have been fielded by SD staff. Their replies almost always refer the questioner back to the standard wiring instructions supplied with the product. (Conveniently sidestepping the fact that the standard wiring instructions fail to satisfy the customer's non-standard requirements.) So much for customer support.
    There used to be a couple of idiots who tackled the difficult/custom/bespoke/weird wiring questions. One of them used the forum ID Blue Talon.
  • I'm definitely guilty of posting without thinking it through sometimes, although, for better or worse, that's credit to the patience and support of the members here who have tolerated and assisted in abundance (@ICBM wins the platinum award). Sometimes, it's just seeking reassurance but in this case it was entirely down to lack of experience and confidence. Both gained, now knowledge required to support some much-needed technical skills. This post went from asking a simple question or two into rushing an order and cracking into it. Definitely no anger throughout - just struggling to wrap my tiny wee mass of grey matter around some of it.
    There have been only a few times when I have been annoyed by this anybody within this community - and I for one am grateful for the support. Hats off to y'all.
