I've never had anything BUT trouble with those, though I have never used a lubricant on them.
Too eliminate them from the equation, unhook the strings and retune as I suggested.
If the problem persists, it's something else.....
A little "nut sauce" on any point there's contact between string and guitar (Bridge/nut/trees) and a little on the trem posts has sorted any issues on my Strat. Any one of those can cause tuning stability issues.
Also, if the strings aren't stretched in properly then that can cause stability issues too.
All happened on my own Strat, with 2 post trem.....
Lots of great advice so far. You have to eliminate the nut as the problem first because probably nine times out of ten it is.
A simple test, tune up, bend a nore on the string, check tuning, is it flat? Retune, this time bend the string behind the nut, check tuning, is it now sharp? It the answer to both is yes then the nut slot is a problem (it might not be the whole problem but you must eliminate it). Repeat for all strings.
Polish, file, fettle the slots and lubricate with pencile graphite and maybe vasaline.
I recomend a lip balm stick - just rub it across the nut and give the wobbly arm a bit of stick. Works a treat
