standard push pull - two functions at the same time?
Seems a bit of a daft question, but then I am a bit daft ...... A push pull pot switch generally has 6 small terminals, presumably you could wire it up to do two functions at once eg change HBs both to single coil at the same time?
  • TTonyTTony Frets: 27690
    Indeedy.
    (there should be a wiring diagram pdf attached to the post above, let me know if you can't see it.).
  • prowlaprowla Frets: 4948
    If it's a DPDT switch, then it can be wired to do two things.
  • axisusaxisus Frets: 28342
    Yeah, got it thanks. Not quite sure if my plan will work but I can think about it now ...
