1974 Fender Pro reverb amp
Lez325Lez325 Frets: 82
edited October 2017 in Amps
Hi guys, I have been offered this amp in a trade against some gear I'm selling for £450
I'm not sure what it would be worth, needs a service I've been told...
https://i.imgur.com/KxazlzQ.jpg
any thoughts ?
Thanks in advance
Les
  • RiftAmpsRiftAmps Frets: 3180
    Depends on condition, but between £600-£900
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
  • Lez325Lez325 Frets: 82
    it looks well used ( see image above) but sounds 100%
  • John_PJohn_P Frets: 2750
    "Needs a service" could cover a range of problems but I would think that's a decent price if the internals haven't been modded.   Factor in the price it possibly needing caps and/or valves replacing.
    Back in in the day when these weren't very fashionable I swapped one for distortion pedal.  Needed some work on it but still a stupid decision- I'd have another one if I could.
  • ICBMICBM Frets: 72619
    That's not a '74, it's '76 or later and is the 'Ultra-Linear' 70W/solid-state rectifier version - you can tell by the mid controls (four knobs on the Normal channel) and master volume.
    These are much less desirable - although still a very good amp, they are louder and harder-sounding, and much heavier - more like a slightly quieter Twin than like the earlier 40W Pro.
    £450 is about right or maybe even a little high if it needs servicing and that is an unknown quantity. SF Fenders can need fairly substantial work now, but even if it's just a simple re-cap and cleanup that's a £100 job or so, and it could be worse.
    Thanks Guy's I think I'll pass on this deal - could cost more than it's worth :(
  • DJH83004DJH83004 Frets: 196
    Good call in my opinion, they are not that much lighter than a Twin Reverb, so still a big lump to carry around if you are gigging, and as IC says, the SFs are starting to cost money to get up to scratch, particularly if caps, valves, reverb tanks, speakers, scratchy pots etc. come into play, which is what I am finding to greater or lesser degrees these days.
    All that said, the ultra linears are very loud and very clean.
