Noob question about wiring a pot
Hi,
I have a question about this part of a schematic:
https://imgur.com/a/nLyfJ
Does this mean that I have to do all the following:
- wire pin 1 to pin 2
- wire pin 1 to ground
- wire pin 2 to ground
- wire pin 3 to the rest of the circut (ie the resistor and cap)
Please let me know if I have this incorrect!
  • FunkfingersFunkfingers Frets: 14594
    Before answering this question, it will be necessary to agree on a pot terminal numbering convention.
    Then, it will be necessary to confirm the function that you require the pot to perform. Guitar volume, guitar tone, guitar blend, amp bias et cetera.
  • ICBMICBM Frets: 72720
    Pin 1 goes to ground
    Pin 2 goes to ground
    Pin 3 goes to the resistor and cap
    What is the circuit for - something like a presence control which is in a negative feedback circuit? If not, turning the pot 'up' will reduce high frequencies.
  • liamonliamon Frets: 103
    edited October 2017
    Sorry here is the full schematic. it's a bias pot for an overdrive pedal.
    https://imgur.com/a/aQXaX
    Thanks ICBM, very helpful.
    edited October 2017
    Thank you. Context is important.
    Remote problem solving from incomplete information is like trying to decorate a hallway, with a toothbrush, through the letterbox.
