I've been using the BluesBreaker clone from Fredric effects almost exclusively for my low-mid gain stuff recently and I have to say it sounds fantastic into a Marshall with both my tele and LP. If I need a little extra girth I feed it with the Koko boost (in mid boost mode for leads). Gain is set to about 2 o'clock, tone at about 3 o'clock and level is about 3 o'clock. My only criticism is that all the action is in the last third of the knob sweep.
The general flavour of the BB is just great.
What's your current drive type of choice?
Not really, a Keeley OD.
https://reverb.com/item/2238718-keeley-1962-union-jack
JM build | Pedalboard plans
I'm looking at getting the little Strymon mini switch so I can set it up for my Strat & tele, as they share settings nicely, and set a "favourite" sound up with different settings for my Les Paul.
What a fantastic overdrive it is, I believe my search for the perfect overdrive is over. It'll do mild boost to balls out rock at the drop of a hat, it pairs really well with my JTM45, I really couldn't ask for a better pedal.
Gives me all I need Drive wise
