Which Boss OD-1?
builttospillbuilttospill Frets: 460
I fancy a couple of Bosses on my board for simplicity reasons and minimal fuss, hugely tempted by an original OD-1 what I should look out for and how do the late 70's OD-1's compare to a late 80's? prices seem to be all over the place. Any help greatly appreciated
  • Modulus_AmpsModulus_Amps Frets: 2596
    The one I had was very bright with no tone control, have you tried one before?
  • JezWyndJezWynd Frets: 6118
    edited October 2017
    The original 14 pin version is the one that gets the love and correspondingly high prices. I've had a couple using the later 4558 ic and I'd say it's a good drive if you can turn up the amp otherwise it loses too much low end.
    Here are the basic revisions -
    http://www.bossarea.com/boss-od-1-over-drive/
  • Never! but I'm intrigued and I'm in a pedal flipping phase currently, how did you find the gain on it?
  • I didn't find the one I tried vastly different to an sd-1 to be honest!
  • "Working" software has only unobserved bugs. (Parroty Error: Pieces of Nine! Pieces of Nine!)
  • ICBMICBM Frets: 72665
    If you want to pay a lot for a Boss overdrive I would get an SD-1 Waza. You get the same basic sound as the OD-1, a tone control, an extra mode and the bypass bleed fixed.
    Yeah the SD-1 Waza is amazing, best Boss overdrive around at the minute.
    Stay away from the OD-1X @builttospill.  it's not bad, but it's not as transparent as the Waza.
