FIrstly because I like the way it's turning out.
Secondly because the edges are all substantially rounded-over, so there's no clear definition line for a change in finish front/back.
Think I might recess the cavity cover into the body rather than it standing proud of the top.
Just need to find a suitable piece of something to use. Possibly a piece of the Ash offcut, probably stained black?
Er....
Why anyone would choose to put a horrible piece of plastic on the front of a beautiful piece of wood is beyond me.
I agree absolutely.
Nil Satis Nisi Optimum
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
I do have an idea in mind for something... a little something... if you had a wee spot in your build schedule
Cool stuff.. Love the colour.. I want to use a Crimson stain and their oil on an upcoming build.... Anyone used their oil?
I used ebony dust as a grain filler once when I was doing a natural finish but wanted to highlight the grain.. Came out pretty cool I think..
https://i.imgur.com/sDuxCWP.jpg
https://i.imgur.com/FKDBm64.jpg
https://i.imgur.com/Qx4kXg6.jpg
Ive also wanted to do a bass project for a while... Maybe early next year...
http://www.rabswoodguitars.co.uk/
https://www.facebook.com/RabsWoodGuitars/
My Youtube page
Got the back black-stained, rubbed back and re-stained now too.
Looks pretty similar to the front after one coat, so I'm happy that it's going to progress in a similar way tomorrow.
The neck has been tru-oiled and wet-sanded. The flame is starting to emerge
The neck is also starting to feel like only something that's been wet-sanded wtih tru-oil can feel.
Silky smooth.
Real quality silk silky smooth.
As an aside, loving that stain @TTony that’s come out very well.
Today:
Third coat of Crimson (Cherry Red) stain on the body, front and back, and then a couple of coats of Eze-Oil on the front.
Pics just after the second coat was applied
I'm thinking perhaps one more coat of Eze, and then some wet-sanding & buffing.
Also, I hadn't realised that the P p'up cavities are routed in the expectation that they'd be covered by a scratch plate.
So I'm currently having a bit of a rethink, and trying to decide just how brave I want to be.
- The easy, but aesthetically unpleasing, option is to put a standard-ish scratch plate on it.
- The still easy, and less unpleasing, option is to cut down a standard plate to cover the p'up & control cavities
- The still easy, as above, but make the custom scratch plate out of some more interesting material
- The less easy, but more pleasing, option is to make some p'up surrounds and go back to planA for the control cover
(plan A was to inset the cover material into the body, and I think there's a bit of scrap Ash that would serve the purpose with good enough grain matching).I also realised that I should really have marked out the position for the bridge - and drilled the holes - before starting to put the finish on. It's been a while since I've put a guitar together, and I was too impatient to see if the finish idea would work out. No biggie, I'll just have to use plenty of masking tape tomorrow.
