Any metalworkers here?
I can manage wood working (ish), but have no tools or capability for metalworking.
I'm trying to find something like this, for a  pair of Precision bass pickups
Google found me the image, originally from the US allparts site, but it's not in the current catalogue, so I can't even source from the US.
Anyone able to help with suggestions?
  • GSPBASSESGSPBASSES Frets: 2355
     I believe  David Dyke  sells them, they are made by ABM, not sure if they are still available though.  I'm going to DD's tomorrow I'll have a look for you .
         You should have taken the Mahogany P-Bass  with the Bur Maple cap I showed you, as that come with a pair of those,  as they are the last pair I have I can't help you with them .
  • TTonyTTony Frets: 27855
    If DD has them, then yes, please  grab me a pair @GSPBASSES ;
    That  other body looked beautiful - it was just you describing it as "heavy" that put me off.  But you should put it up here and let @Bridgehouse talk you into selling it ...
    Who? Me? No way! ;)
    This is the beautiful P-Bass, but it is a bit heavy.
    Two thoughts spring to mind:
    "Wow. That's amazing!"
    "Ooooh me lumbago!"
  • m_cm_c Frets: 1251
    @TTony if you had an accurate dimensioned drawing/model, that's easily doable.
    I'm assuming it's just aluminium?
    I guess aluminium would be fine - it's not bearing any stresses, just covering the pickup cavity.
    @M_C - are you talking hypothetically, or are you skilled at such things?
  • Modulus_AmpsModulus_Amps Frets: 2606
    Would be pretty easy to get one drawn up, water cut and drilled out. If you get really stuck let me know and I can help.
    Somewhat skilled. My side business involves creating masses of aluminium swarf, using various bits of CNC and manual metal nibbling machines.
    Alternatively if you've not got a drawing, but have a plastic equivalent, I've got a digitiser, so can get a drawing that way.
