CAE 2x12 ported cab
monkey42monkey42 Frets: 341
edited November 2017 in Amps £
fantastic John suhr designed cab to match a 4x12
this Cab is loaded with V30 at 8ohms
cab can be used in either vertical or horizontal
good condition
pm me for photos
£400 collected
  • Great cabs I have two of em!
  • monkey42monkey42 Frets: 341
    Bump
  • KimKim Frets: 31
    I've got one with g1265s, am thinking about a 2nd. @rockmonster ;do you run 2 at the same time? Does 2 together sound similar to a 4x12 or is it a different vibe? Also, what speakers are you running in yours?
  • rockmonsterrockmonster Frets: 839
    Mine are currently loaded with celestion creamback M65s which go well with my EVH heads. I’ve mixed them and used a few different speakers- they always sound good to me. They work well with all the heads I have used-Diezel, CAA, Friedman everything! I use a pair for gigging most of the time. As they are ported at the front I stack them horizontally and they sound big! I sometimes use them vertically and point them outwards for a bigger spread. Together they sound to me like a front loaded ported BIG 4x12. They also sound superb with V30’s which is what they were designed to be used with. I’ve used them for quite a time. Better than ALL the 2x12’s I’ve ever had IMHO.  Including Friedman, Bognor, Mills Acoustics, EVH the lot! AND they are really portable! I love em! With the Friedman amps they sounded great with V30’s in the bottom cab and  creambacks on the top.
    Thanks boyo
    I agree, it’s probabl the best 2x12 I’ve ever owned. I’ve had most of the above plus port city, Jackson ampworks, etc.
    nice and compact to
    oh...and bump^
  • KimKim Frets: 31
    Very helpful info thanks @rockmonster ;
    One more try
    if not then I’ll keep it, as it is a cracking cab
