Is there anything special about the RV3?
TeetonetalTeetonetal Frets: 7810
I notice that they regularly sell for more than the RV5, any reason why?
  • DopesickDopesick Frets: 1510
    They're not very versatile, but what they do they do INCREDIBLY well. Basically if you want post-rock in a pedal then this is it. The reverb sound is quite...lack of a better term...cold, but can get really cavernous, and the delay can get really glitchy if you max out the feedback as it doesn't self-oscillate.
  • GadgetGadget Frets: 896
    The RV-2 is very well thought of.
    I think, therefore.... I... ummmm........
  • AFAIK, its because it does full wet with no direct signal. I never used it like that and was glad to sell it at the time.
  • yeah, I would say it’s the Post Rock thing too. Loads of bands particularly Explosions in the Sky were stockpiling RV3’s. I have a RV6 that I use for a full wet/ full decay “big” reverb (as apposed to my Holy Grail which is the “small”) and it sounds incredible and a million times better than my friends RV5
  • ICBMICBM Frets: 72505
    It's a great pedal if you need delay and reverb in the same box - the RV-2, 5 and 6 only do reverb.
  • The RV-5 isn’t here to defend itself, behave. FWIW, the modulation setting on an RV-5 is wonderful.
  • FuengiFuengi Frets: 2850
    The RV-6 does have a delay setting. Sounds great.
    Ah, I missed that. What reverb does it use in the delay setting?
    Good question. I was going to check today but forgot.
    From memory I think it's a plate reverb but might be wrong. It works really well with the delay which is controlled by the tone knob.
  • I notice that they regularly sell for more than the RV5, any reason why?
    The Radiohead connection as much as anything. The RV-5 has such a lovely modulated setting. The RV-6 isn't bad either.
  • It has a flaw in that the signal drops when switched on and off.
