The SKB 2U Roto Rack is the ideal companion for any live sound professional, perfect for housing a range of outboard gear from compressors to signal processors and more. The case itself is constructed from rotationally moulded polyethylene for maximum strength and protection. This heavy-duty design ensures your equipment is kept safe and secure at all times and resistant to impact damage. The unique design of the SKB Roto Rack makes it easy to interlock thanks to its integrated stacking ribs. The front and rear panels of the case can also be removed for quick and easy access to your equipment. The exterior of the case features recessed latches, front and rear gasketed covers and heavy-duty flushmount handles allowing you to transport your equipment with ease.
I’ll take this if it is still going
