Slightly urgent - anyone got a V30 8 ohm speaker in Cambridge to sell me tonight?
vizviz Frets: 10720
as above
  • If you were closer viz, I could lend you an amp with one in.
    Hope someone sorts you out type Bump.
  • vizviz Frets: 10720
    Thanks dude
  • Might it be easier to try to borrow/hire an entire cabinet rather than buy a single speaker at such short notice?
    You’re right but I need it for a wedge monitor.
    If you were closer, I'd still be fook all use to you...
    Correct :)
    unless you were happy to unscrew yours and lend it to me!
    I’m going to take my 2x12 which is 8 ohms, unplug one of the speakers, so it’s 16 ohms, and run it in parallel with my wedge monitor which is already 16 ohms.
    (Is that right, @ICBM ?)
  • viz said:
    Correct
    That'd be no problem, 5 minute job, but 3 days travelling.
    viz said:
    Correct
    Why can’t you be ourmanineastanglia
