Does that mean I should be using two cabs, each running at 8 ohms, which the amp will run in parallel at 4 ohms?
What’s the logic behind this output as opposed to a Marshall double output with an ohm selector?
Cheaper to do and more reliable - a third jack is less expensive than a selector switch, and old Marshall selectors were notoriously unreliable and a major cause of blown output transformers.
