Depending on your ear/amp you may find three JJ in the pre amp a bit dark, I don't know that amp, also if you buy the kit only replace the pre amp valves where needed, keep a few in a drawer for when you really need them
Cheers.
I will get that set and try replacing all of the power valves and see how it sounds. Then I'll try the preamp valves and see.
It could be that the amp itself is knackered, in which case I'll have lots of spares
Thanks for that, I will try and pick some different ones up on eBay and have a play.
