http://thefretboard.co.uk/discussion/119321/
Also although it correctly always under tunes and then comes up to pitch it has no way of pulling the string first, which is something I always do
For string changes though and as a roadie tool it's ace
Plus the fact you can use this on all your guitars. Buy once, use on all...
"its like having a guitar tech in your pocket!" no its not, its actually having a tuner and string winder in one in your pocket.
Im sure it has its uses but at £114 for a tuner its not something Id even consider to be honest.
Just because you're paranoid, don't mean they're not after youRemember, it's easier to criticise than create!
But a gadget which does the same thing without being attached to the guitar? It's not such a bad idea. Still unnecessary, but not a bad idea.
