Fuzz into wah or vice versa?
WillEdmundsWillEdmunds Frets: 168
edited December 2017 in FX
I'm using a Fulltone 69 Fuzz into an Xotic XW1 wah. I wired the fuzz into my board first due to the general consensus that fuzz works best first in the signal chain. It just sounds a bit shit when I'm after those Hendrix fuzz and wah tones. I've tried it both ways and neither are great to my ears. I know that Jimi seemed to run fuzz before wah but don't get how he sounded so great!
I know its an age old debate but any suggestions? Buffer between fuzz and wah perhaps?
  • antifashantifash Frets: 603
    I always put wah first.
  • LebarqueLebarque Frets: 3903
    Wah, fuzz. The Xotic is fuzz-friendly, so should sound great.
  • hotpickupshotpickups Frets: 1822
    Xotic wah I pot first as it's buffer friendly for fuzzes etc . Then my fuzz and sounds fine
    Funnily enough though two pedals I hardly use :(
  • bbill335bbill335 Frets: 1389
    if you're doing it properly and there's a dirty amp or OD pedal after the fuzz and wah, I think it always sounds best fuzz into wah.
  • tampaxbootampaxboo Frets: 489
    maybe the wah is 'spectrum bracketed' in a way the fuzz doesn't like?
    eg. the wah is only offering the fuzz a bracketed slice of tonal content which, because of the nature of that particular fuzz circuit, it can't do much with.
    for a full fuzz tone you need a full tonal range in, once you filter that range (wah is a variable filter) you are limiting raw materials the fuzz has to work with. harmonics and overtones stripped out. octave fuzzes work well after wahs as they add new info rather than only distorting input.
    it may also be that your wah has a funny range. if has an option to vary range, or an internal trimmer (mark starting point before tweaking so you can easily get it back), that might be another way to approach resolving this.
    i am the hired assassin... the specialist. i introduce myself to you... i'm a sadist.
    This is good to know! I just built a Temple board with custom cable. Took me ages. Looks like I'll be re-doing it to put the wah first though...
    My Crosstown fuzz didn’t play nice with a wah in front (impedence). So it went.
  • ICBMICBM Frets: 72661
    Jimi mostly (or always, I'm not sure) used wah before fuzz, as here -
    https://i.pinimg.com/236x/63/05/51/630551a3dd870876752959d7983e7783--jimi-hendrix-experience-guitar-players.jpg
    One problem is that with modern cables, that can sound very shrill because there is much less capacitance to suppress the high frequencies - or it can even oscillate. FoxRox make a buffer to fit inside the wah (between the circuit and the switch, so it's bypassed when the pedal is) which fixes this.
    Silicon FFs are more forgiving than their older Ge brothers, based on the different stuff I've tried. Hendrix used both and has been pictured with his wah both ways. It's probably just a case of whatever worked with what he had on the day. The other thing is, maybe he got a shit tonne of oscillation running the wah first and just didn't give a fuck coz he was out of it! No oscillation with the fuzz first, ever.
    I think the fact he was Jimi might've had something to do with it.
    Very true of course. His unparalleled playing aside, I was thinking more about the interaction between fuzz and wah!
  • WillEdmundsWillEdmunds Frets: 168
    Thanks all. I've rewired my board with wah before fuzz and it sounds a lot better than it did.
  • Ro_SRo_S Frets: 929
    both
    over 20 effects pedals FOR SALE, click here to see my classifieds thread.   My trading feedback
    Effects for Me & my Monkey
    YouTube channel     Facebook         Fretboard's "resident pedal supremo" - mgaw
    Good to hear. I thought that should work fine. Enjoy.
  • BabonesBabones Frets: 1207
    Classic wah sounds: wah before dirt.
    Noise terrorism: wah after fuzz/dirt
    The former is better for classic rock/blues etc
    The latter is better for shoegaze/ambient/'grunge'/noise rock etc
  • shaunmshaunm Frets: 1633
    I use a 69 with a Buddha Wah before it. Works a treat. Tried it the other way and didn’t like it.
    Great fuzz pedal though!
  • p90foolp90fool Frets: 31664
    This ^^^
    Also, never underestimate the importance of a pushed amp at the end of the chain to smooth out weird frequency/volume spikes.
