Help identifying old poweramp
sgosdensgosden Frets: 1994
Dad found this amongst all his random tat.
JPS SC100 - 100 watt slave power amp,
https://imgur.com/gallery/vjucj
Anyone got any info? more to the point is it worth anything or is it destined for the skip?
  • ICBMICBM Frets: 72809
    Something old, generic and probably fairly well-made and reliable. It's big, looks heavy and will no doubt contain a big transformer and discrete components. From the size of it it's likely to be a genuine 100W.
    If it works it's useful as a power amp or a backup amp. Probably worth no more than about £50, but I wouldn't throw it away.
  • sgosdensgosden Frets: 1994
    Cheers @ICBM,
    seem to remember it was in a box with an old HH amplifier, which got sold.
    if its just a power amp, could it be used to power speakers for Helix?
    Yes.
    The question is whether it's in good working order - with something of this age, leaking/failed filter caps are quite likely. Probably worth a look inside before you power it up - I should have mentioned that before really!
    ICBM said:
    Yes.
    No worries , taking it apart for a nose/check was first on my list :)
  • DJH83004DJH83004 Frets: 196
    Just be a little bit careful when opening it up, even though it is SS, there could still be +/- 75volts in there, with very large power supply filter caps - certainly enough to blow the end off a screwdriver  :)
