What do you call....
The cover that goes over a single fret so that you can use wire wool without destroying the fretboard itself
  • GizmoGizmo Frets: 1078
    Fret guard?
  • that's the bad boy!!!! Ta
  • randellarandella Frets: 4248
    They were sold originally as eraser guards for technical drawing, I believe.
    I've not yet needed to replace mine, so not had an opportunity to see if they're sold any cheaper under their previous guise.
  • WezVWezV Frets: 16781
    If you are using wire wool which may destroy the board, you are using the wrong wire wool.
  • Precaution @WezV , I'm using 0000 to clean them up bud
  • ChalkyChalky Frets: 6811
    Crimson Guitars now do some abrasive rubbers - far far easier and less mess than wire wool for polishing frets.
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8825
    I’d second the Crimson rubbers (even though I haven’t used them) simply because wire wool is evil.
    Ben uses them in a video in which refrets kelly Jones’s SG.
    I have the crimson rubbers.  I prefer wire wool
  • GSPBASSESGSPBASSES Frets: 2351
    +1
       I use masking tape either side of the fret to protect the fingerboard, but then, when cleaning up the end of frets, I remove the masking tape and clean the fingerboard up at the same time with the wire wool.
  • The Crimson rubbers are handy, but it's hard to beat wet&dry sandpaper. I don't like wire wool due to the way it showers conductive metal particles everywhere.
  • Micromesh was recommended to me recently, it is also worth a go.  Less mess than wirewool, will cost more though
  • I love the Crimson rubbers
    I use those too, but still use wire wool.
    tbh, the last few fret jobs I have done have been a combination of wet and dry up to 1200g, micromesh up to 4000g, liberon 0000 wire wool, then micro micromesh again up to 12000g.   I have used the crimson rubbers in there too, but they have not found a permanent place in my method yet.  I often finish with a tiny amount of T-cut on a microfibre cloth.
    They are all good for certain stages
  • SargeSarge Frets: 2429
    I use micromesh exclusively for frets, but I swear by cheap blue masking tape to cover the entire board, it's amazing what shite the tape gets out of the grain on a dirty rosewood board, gets it ready for a good toothbrushing and oiling.
    Hehe he said like "rubbers" heheheh.
    What with the fingertip rubber protectors and this thread, I think the FB has gone all BDSM and stuff.
  • Hehe he said like "rubbers" heheheh.
    Protect and serve? ;)
    "When the train, it left the station, there was two lights on behind,
    Well, the blue light was my baby, and the red light was my mind.”
    Robert Johnson
