As already mentioned in another thread, my new year project is to ‘Esquire’ (any noun can be verbed) an MIM Std Tele.
My first thought was to keep the six-saddle bridge so the guitar could be properly intonated. However I’ve just yesterday played a Tele with a three-barrel bridge and was surprised at just how comfortable the lipped sides are. So, now the plan is to fit a Gotoh BS-TC1 (or TC1S) bridge which looks as if it should drop right in.
Anyway, the dumb question...
The replacement bridge is supplied with mounting screws. However, since Teles come from Mexico, Japan, and the US I guess I shouldn't presume that the supplied screws will match the originals. Am I best just reusing the originals? See, told you it was a dumb question but then this is my first project.
Instagram
Also, always make sure the screw 'finds' the thread of the hole by turning it backwards until it drops in - if it cuts a new thread it will drastically weaken the wood.
OK, this doesn't matter that much on a through-body Tele bridge because the screws don't really take that much force, but it very much does on neck screws...
I must admit to wondering whether through-body stringing was an engineering solution by Leo so that the strings would pull the bridge towards the body rather towards the headstock.
Recent ones use four screws in the same positions as a vintage-style American stamped steel bridge.
Older versions use three screws in approximately the same positions as an American Standard machined bridge.
The through stringing holes may also be in different positions.
Since the vintage style bridge covers a smaller area than the modern type, the change may reveal differentially faded finish and/or compression marks in the urethane.
Instagram
