Folks.
The CNC machine (not mine) should start cutting my St Vincent inspired body today, so I'm now considering wiring options...
Mine will have three P90's, which will be wired through a Start 5 way switch and 1 vol 1 tone..........the real thing is Mini buckers wired (from switch in normal Strat bridge position) Bridge/Middle/Neck/All Three/Bridge and Neck together........can I do this with my P90's and just the Strat switch?
A photo of a drawing, scrawled on the back of an envelope would be appreciated, if not possible then it will be wired as a normal Start........
Cheers!
Stranger from another planet welcome to our hole - Just strap on your guitar and we'll play some rock 'n' roll
The simplest way to get the sounds you want (although not quite in exactly the order) with a standard Strat switch is to use a push-pull pot to turn on the bridge pickup in any position. I did that with a PRS Custom 22 Soapbar.
Thanks folks!
Another one to consider if you can't get either a push-pull or a Superswitch to fit is to deliberately use the 'wrong' order on the switch, swapping the neck and middle pickups, so it goes bridge/bridge+neck/neck/neck+middle/middle, that would get you at least one of the extra sounds you want.
It can be persuaded to do all three in either position two or position four.
