If you're getting fretbuzz that should be a neck/truss issue or a high fret, usually not a bridge issue.
Is it a) everywhere b) at the low frets c) at the high frets or d) at only one or two specific frets?
Mine is a 2006 MIJ, strung with 11s. If I had mine that low I'd definitely get a lot of fret buzz.
I don't think there's a shim (never checked), reckon the neck might be too straight?
I'll try and get some photos
that would explain why my mastery was on stilts when you sent it back. I had to drop it a shitload after you borrowed it.
