So I'm at a place where I'm happy with my board. I have everything I need for my current band, if not I'll swap the odd pedal out.
However the SIB Echodrive is causing me problems. I've always used a Pedal Power 2+ so I've used the IEC output at the back.
Now I'm using GigRig power, it means I'm going to have to have 2 mains cables running from my board. Only thing I can think of is buying a 2 male to 1 female IEC cable, but if there anything easier than that that I'm missing? You'll see the mess it looks on the top left of the board with the ED unplugged.
http://i.imgur.com/NztYZrZ.jpg
Y Splitter Mains Kettle Twin Power Lead PC & Monitor https://www.amazon.co.uk/dp/B000Q6I2EY/ref=cm_sw_r_cp_api_IPeNAbWT7HHK2
£6 and change on the website I found it.
Kyle, thats a mighty fine quadrant of delays you have there !
