Setting up a mini board, need pedal suggestions...
  • samothy01samothy01 Frets: 33
    samothy01 said:
    +1 on the Rat. It’s surprisingly versatile. For a tuner, consider a Sonic Research mini turbo tuner. An amazing strobe tuner, and tiny.
    And you you could try a Deluxe Memory Man Tap Tempo 550. That’s delay and chorus in one, and also a really, really good clean boost.
    I’ll absolutely try out a rat eventually, it’s just getting around to it! I haven’t done much research into it but am I right in saying that the sonic research tuner is quite hard to come by???
    Ah my friend has a 550 and it’s superb, great recommendation.
    Yes, I had to order my Sonic Research direct from the manufacturer. It was worth it though. Easily the best tuner I’ve ever used.
    Okay, thanks for the tip, I’ll have a look into this one.
    rico said:
    I would go TU3 -> EP Boost -> OCD -> chorus of some type -> Carbon Copy.
    I think I’m really leaning towards the OCD, I enjoy the look of the pedal as much as the sound!
    Jalapeno said:
    Xotic XP booster and whatever else you fancy - that's my approach
    Have you used one? What’s your experience with it?
    samothy01 said:
    The circuit I continually return to is the MXR Distortion+.
    Cheap as chips, sounds great
    I’ve done a lil bit of research and although I’m not really impressed, they are super cheap so I feel like that makes up for it!
    Im not particularly after a pedal which can go fuzzy and for what I’d  it for I think I could cover off with an even cheaper DS-1... possibly.
    Its probably not a circuit for everyone but its absolutely the sound in my head!
    I actually really like mine with the gain down really low, which is a sound I probably use even more than I use it cranked up.
    I’ve been trying to find that sound in my head for years, still no one has made it! So I know your troubles...
    But thanks for the recommendation, I’ll certainly do more research!
    So I’ve gone completely rogue and started this board off with a Digitech Whammy 4 because...... artifacts  :)
    For distortion I’ve decided that I want a Klone of sorts, anyone know any cheap copies???
  • BabonesBabones Frets: 1207
    J Mascis has a couple of Mooers on his (Mooer) fly board, including the Hustle Drive (OCD Clone).
  • VJIvesVJIves Frets: 466
    edited March 2018
    The Boss TU3s is a great little tuner. Emphasis on little.
    VJIves said:
    The Boss TU5s is a great little tuner. Emphasis on little.
    I have a TU3S on my main board, it’s tiiiiny and I love it
    edited March 2018
    Oooo any experience with it? (The hustle drive)
    @babones
