normal setup stuff. the saddles are quite high so you definitely have room to lower them.
It may well have been set high for a reason. The nut is clearly high too.. hard to say if the truss rod needs a tweak fromt eh pics.. it looks like it needs a full set-up to me, but given the value its probably worth trying yourself
What do you have it tuned to? Try A - D - G - C - E - A
Instagram
