Finished Pics! C18Q1 Swift Lite Version 2
124»
    Remade the knobs.  I think these will do OK - a bit more subtle than the larger MoP dot :)
  • RolandRoland Frets: 8709
    I prefer them
  • BigMonkaBigMonka Frets: 1772
    That looks spot on (if you'll pardon the pun ;-) )
    Suits the figured top more than a metal knob too, IMO.
    edited March 2018
    On the home straight now - the finishing
    I've spent a bit of time sanding out rough-sanding lines, smoothing curves and starting to get close to the finished neck profile (I'll finally finish that once it's all strung up and playable) and now started the slurry-filling and preparation for varnishing.
    The figuring on this amboyna simply HAS to have full gloss, so I'm going to revert to Ronsealing the body and tru-oil slurry and buff for the neck.  But, I also slurry and wipe with tru-oil before applying the gloss - I find it shows up any missed sanding marks and also produces a wonderful grain-filled base for the gloss coat.
    Got a bit more to do on the back, but the top is just drying fully before the first gloss coat:
    The back is almost there - just a touch of sanding work remaining around the control chamber.  I will also deepen the hatch rebate before the gloss goes on:
    Oh - weight at the moment, 3lbs 11oz
    After a couple of slurry-and-wipe sessions with Tru-oil, I've then given it three wipes with slightly thinned Ronseal Hardglaze applied, as usual, with a budget soft micro-fibre cloth.
    Although the new formula Ronseal is a bit quirky and doesn't self level quite enough, this is probably the quickest I've got to an acceptable finish at 3 days total from sanded wood:
    After a week of letting it harden fully, I will polish it up properly with Meguiars Ultimate compound but this is perfectly tough enough for normal handling already so hopefully the build will be finished over the next 2-3 days :)
    Getting closer.
    Piling everything left to fit onto the digital scales, the total final weight is looking like it's going to be under 5 1/4 lbs :)
    And finished!
    I've wired the electrics '50's style' to give a broader range of tone possibilities if Jane needs them in the future and added magnets for the cover with a thumbnail access:
     I know slim guitars, fancy wood guitars and gold trimmings aren't everyone's taste but, ladies and gentlemen, here is my C18Q1 entry:
    I present to you the 5lbs 4oz Swift Lite Mark 2 ;)
    As always, many thanks for the encouragement and help along the way - always greatly appreciated!  :)
    That's stunning Andy, you should be very proud and I hope the new owner loves it!
    Stunning Andy!
  • impmannimpmann Frets: 12667
    Lovely!
    We ought to get all of the 'Slim Swifts' together (basses as well) for a jam. ;-)
    impmann said:
    Lovely!
    Now there's a thought! :)
    ... and thanks for the feedback, folks :)
    It’s been a pleasure watching the build Andy
  • impmann said:
    Lovely!
    Good band name, that.
    ...or Byrds Lyte
  • So glad I found this, absolutely amazing.
  • Simon_MSimon_M Frets: 542
    Just read the thread from start to finish. Great work and really encouraging for my own build.
    That's great - thanks!
  • Adam_MDAdam_MD Frets: 3420
    Wow I missed this one Andy you have serious skills sir I always love reading your build threads.
    Thanks, folks - and particular thanks to @ThePrettyDamned ; for giving the thread a bit of a revival :)
