Does it reduce if you move /angle away from the amp
have you tried the amp/guitar in another room?
Plugged the amp straight into the wall, no extension leads
tried the setup with no effects boards and no effects power adapters plugged into the same line as the amp
turn off the lights/computer etc
It's fairly normal, although it does vary depending on how well shielded the jack and control cavity are.
Ill be back with result?
Trying the guitar with another amp would help too if you can.
There is no such thing as a 'DC hum' - by definition DC does not cause hum because it's 0Hz. You don't need to separate DC and signal cables for that reason - assuming the power supply is decent quality and isn't actually leaving a ripple on the DC.
