SORTED: Audacious WTB: Dual Footswitch Hudson Broadcast
jacklawteyjacklawtey Frets: 284
edited April 2018 in FX £
(I think) I’ve got a deal for a single footswitcher, which is great, but I’m also after a second dual footswitched version. I know this is a long, long shot but you never know - good bunch on here.
Thanks!
  • jacklawteyjacklawtey Frets: 284
    Bump
  • JonHoskerJonHosker Frets: 395
    Jack
    Peach Guitars have anout 60 special 24v ones coming in early Summer....not sue what date/month this means...
    You can ring tjem and be put in the waiting list
    I snagged one from this amazing forum!!
    Happy pedal searching.
    Jon
    Thanks for the tip Jon! Appreciate it, glad you got yours. How’re you liking it?
    edited April 2018
    Amazing...left side on always as base tone and right side for a bit more...need to tweak internal gsin control.
    Early days for me.
  • mrkbmrkb Frets: 6922
    Aren’t the peach guitars one brightpink?! Not sure I could go with that vibe on my pedalboard.
    Karma......
    Ebay mark7777_1
  • smudge_ladsmudge_lad Frets: 672
    JonHosker said:
    Jack
    Jon
    Am I right in thinking the 24v ones use an internal charge pump to take the 9v up to 24v?
    And that the standard version can run anywhere from 9v to 24v, which in theory makes it more flexible?
    Do the 24v ones have the option to run them at lower voltage too? Obv the 24v increases the headroom, but that’s not always what some folk want.
  • LebarqueLebarque Frets: 3905
    JonHosker said:
    Jack
    Jon
    Am I right in thinking the 24v ones use an internal charge pump to take the 9v up to 24v? YES
    And that the standard version can run anywhere from 9v to 24v, which in theory makes it more flexible? YES
    Do the 24v ones have the option to run them at lower voltage too? Obv the 24v increases the headroom, but that’s not always what some folk want. NO
  • yorkioyorkio Frets: 173
    I'd try Mansons and Northern Stompboxes too - when I asked Hudson about availability of the dual Broadcasts, Michael told me that they'd both be getting stock in the next month or so. That was about three weeks ago so I guess that would be about now-ish.
    I also asked about differences between the 24v and 9v versions and he said:
    “The Broadcast and the 24V Broadcasts are the same circuit except for the voltage booster in the 24V model - so the regular Broadcast ran from a 24V supply will sound and react the same as one of the 24V Broadcasts. The only other difference is that the 24V models have a 3-way toggle switch versus the 2-way on the regular - this extra position on the 24V model was added to offer an approximation of the low-gain sound of the regular Broadcast, when ran at 9V.”
    So you can get all the tonality available from the 24v pedal from the 9v, plus, he said, "some in between variations by running it at 18V or anywhere between 9V and 24V."
    Great stuff all around, appreciate it! I emailed Northern Stompboxes since I’m round the corner, still gonna be a month or two!
  • wesker123wesker123 Frets: 496
    Peach Guitars pre-order is on their site now.
    Dual footswitch version.
    Appreciate the heads up very much! Seems luck isn’t on my side and I paid over the odds about 12 hours ago on a £200 one from Reverb. Suppose £30 over RRP to skip the wait isn’t so bad.
  • hotpickupshotpickups Frets: 1822
    You're too rich lol
    Not so! Just impatient.
