Wiring help!?!
andy7561andy7561 Frets: 0
I apologise for what is a maybe a simple question but I’m having some wiring problems.
i recently bought a new gold foil pickup in the style of the old Harmony/airline pickups and I can barely get a sound out of it. I’m wiring it with one tone and one volume. Even when I connect it straight to the jack - nothing or at best very little. I know the pickup is good as this is the second one and it’s been tested.
Does anyone have any ideas? I’m a bit new to wiring but what I have done in the past has been ok.
  • ICBMICBM Frets: 72764
    Disconnect it from the jack and tape the wires to the end of a known good guitar cable, and test it like that.
    Although rare, a shorted jack is not impossible, if it's a far-east-made one - I've never come across it with a Switchcraft.
    Also check for shorts somewhere around the jack, if the cavity is shielded. Sometimes the jack can contact the shielding and short itself.
  • andy7561andy7561 Frets: 0
    Great- thanks
  • FunkfingersFunkfingers Frets: 14611
    Tested by whom and in what way? (Never assume that brand new parts are fully functional.)
    For example, can you take a D.C. resistance meter reading from the pickup coil(s)? Can you take a separate reading for the output cable?
    If the D.C. readings are to spec., it is possible that the magnetic material in the pickup has been de-Gaussed - or was never properly charged to begin with. (I once had this happen on a Seymour Duncan custom order pickup.)
    Remote diagnosis is always helped by the inclusion of photographs.
