That Peter Green pickup thing (again!)
  • guitars4youguitars4you Frets: 14469
    edited October 2017 tFB Trader
    I'm led to believe that after G Moore sold that LP he used various replicas and Custom Built LP's from Gibson with BK  replica p/ups fitted on a few of them - If any one knows how good the original p/ups and BK versions are then it is GM and he used those BK versions for a while on a few guitars so some big compliment in there
  • Emiel said:
    the volume drop is very large with both pickups at equal volume. Only at the quietest bits they might have gone for the full OOP effect. It's very clear when they do.
    I suspect my Gibson Country Gent may have a backwards pickup. It had had the wiring buggered about with and was quiet in the middle position which I assumed was due to the modded wiring – previously it had only master vol and master tone so I couldn't roll a bit of one pickup out of the mixed position.
    It's been rewired back to factory spec and is still quiet in the middle but roll one volume down to 7 and it comes back up to expected output – just like @Emiel's description above.
    It's not a problem as my go to middle tone is bridge with the neck rolled down a bit anyway comparatively. I suppose at some point I could get someone knowledgeable on pickup construction to have a look just out of curiosity to see what's going on but I don't plan to try and have it remedied.
  • ICBMICBM Frets: 72751
    Yes, that sounds like they are out of phase.
  • SunDevilSunDevil Frets: 511
    Does 6 months count as a necro thread?
    @icbm was commenting back in Oct about how the Greenie burst has something special going on that's more than just the out of phase thing.
    Came across this old Gary Moore and Phil Lynott OGWT recording: https://youtu.be/W9xyWxXyOOg
    Take a look at timestamp 1:08 - neck pup only and you'd not mistake it for any other Lester
  • FelineGuitarsFelineGuitars Frets: 11649
    BKP wind their neck PG blues pickup with heavy formvar wire as well as the magnet being flipped.
  • rlwrlw Frets: 4739
    and no bottom E string - that's spooky.
