"Anybody can play. The note is only 20%. The attitude of the motherf*cker who plays it is 80%" - Miles Davis
The Avalanche Run seems to be an expanded Dispatch Master. I think it looks great but it is very spendy and I've seen a few people suggest that you really need to use an expression pedal to get the most out of it.
Boss RE-20 is another pedal that I own and love. It's more of a delay than a reverb though. The reverb on it is certainly quite unique and whilst I think it sounds great in the context of the delay on it I think it's fair to say that the verb on it is a bit marmite when used on its own. And again you can't footswitch between delay and delay + verb. It's another dial twist.
Another consideration is the EQD Disaster Transport which has two delays on it, one of which also has reverb. Its mainly a delay pedal though. I'll tell you what mine is like when it arrives on Wednesday!
There does come a point where you have to ask yourself what you want the pedal to do. Are you better with separate verb and delay pedals for example? (a DD-7 plus Digitech Polara would cost about the same as an RE-20 and is arguably more versatile).
Personally speaking if you do want a separate pedal that truly does both I think you can't go far wrong with the Dispatch Master. The verb sounds great and the delay sounds great. They complement each other nicely.
If you want a delay that also does a bit of reverb there are more options.
Absolutely love the Caverns. Definiately worth a look. Also i think Kick Johnston does a great demo of the Space Station.
I'd prefer the combined box option - like keeping my pedal-board fairly simplified. Main use will be a soft reverb with a slapback but will on occasion want it to get fairly swirly.
Tempted by the CKK Space Station as it seems fairly comparable with the EQD DM but way cheaper. Interested to hear your review on the Disaster Transport though...
I am a recent El Capistan convert - the delays are breathtaking and the additional spring reverb is outstanding. Although obviously not to your tastes if you want an isolated reverb.
My music:- https://soundcloud.com/hubobulous
What type, or how would you describe the reverb on the Dispatch Master.
A simple, lovely pedal which is quite unique sounding. Very warm and vavle pre amp-like.
No tap tempo - but a vastly underrated pedal.
