Melody Makers and gigging
So I'm on the lookout for a Melody maker, Either a 1959 model with the wider pickup or a double pickup version - both single cut. I've been curious about these guitars for a while but am not sure if they are usable in a live setting. I've heard the thicker pickup on a 59 MM is almost p90 like with a hint of telecaster. Does anyone have experience of gigging a melody maker?
And on a side note, Is anyone selling? :)
  • randellarandella Frets: 4263
    I don't see why they wouldn't be - like the lovechild of a Tele and an SG.  I've always fancied one.
    What puts you off out of curiosity?
    I'm not put off as such, Iv'e always had a soft spot for them. My main concern is that they will sound a bit thin. I'd like to occasionally use it for a few songs in my set but i just wanted to know whether anyone has used them while gigging and what they think.
  • SteveRobinsonSteveRobinson Frets: 7079
  • Well that pretty much ends the debate haha
  • KristoKristo Frets: 131
    I used to gig my 2 pickup reissue version; sounded ace. Although I replaced the pickups with ones from BG Pickups as the originals were a little underwhelming.
  • @Kristo Yes iv'e heard the pickups can be a bit underwhelming. That was one of my concerns. Which is why i was looking really more towards the 59, I've heard the pickup output is similar to a p90. (Hence the Melody Maker being referred to as a poor mans junior i guess!)
  • I have a single cut early ‘60 with a really chunky ‘59 neck that’s absurdly good, and even have a fat ‘59 bridge pickup to fit one of these days :-)
  • FunkfingersFunkfingers Frets: 14573
    I have a single pickup 1965, 3rd shape. Its Skylark single coil pickup does the "poor man's P90" trick by the simple expedient of rolling the tone pot back to between 5 and 6 then, playing through overdriven valve amplification.
    With the tone pot fully up, the Skylark single coil is certainly bright and a bit thin but lacks the metallic overtones of a vintage Telecaster with a stamped steel bridge. IMO, the sound is more like a Fender Bronco or the bridge position on a vintage Stratocaster that has no tone control load on it.
  • @Funkfingers Great insight - Thank you
  • I wonder if they ever made a 1959 double pickup version?
    According to A.R. Duchossoir, they did but only in November and December of 1959.
    The author pinpoints the pickup cover change from *wide* to *narrow* to mid-1960. The only notional change to the pickup's specification is the bobbin material. Any other variations probably lie within the tolerances for hand-guided coil winding.
    Obviously, my 1965 guitar has the narrower pickup. I do not consider it to be anything special. In my opinion, the "magic" is in the wood.
    The Epiphone equivalent model of the same era is equally worthy of consideration.
  • springheadspringhead Frets: 1602
    Worked for Gary Moore in his Lizzy days:
    https://www.youtube.com/watch?v=C0cuwDyQyIA
  • StrangefanStrangefan Frets: 5844
    Any guitar that stays in tune, plays well and doesn't have microphonic pickups can be gigged :)
  • Blimey i bet those 59 double pickups are rare!
    Yes i think i will be looking out for the epi equivalent too. Although i have seen a nice 59 that I was considering a while back so i may pull the trigger on it, It's still for sale.
  • KeefyKeefy Frets: 2322
    One word: Joan Jett.
