The problem is that the Chinese fakers may have copied a specific example for their fake serial numbers... so it all might still look genuine when it isn't. Not saying yours isn't, of course.
My band, Red For Dissent
The onus is on the would-be buyer to research the distinguishing features and the range of possible serial numbers for the claimed year before viewing the guitar. The number should check out. If the would-be buyer can get a cellular telephone signal, he or she could perform an Internet search on the spot.
It’s neither an unreasonable or unusual request. The OP is overthinking this as far as I’m concerned.
The yard is nothing but a fence, the sun just hurts my eyes...
I'm guessing it's to do with the fake thing and he doesn't know that the fakes have the right numbers.
Still it’s a standard request though - and I wouldn’t hesitate to give him the info if he’s asked.
The question is not "Why does the buyer want the serial number?", it's "Why is the seller so secretive?"
I'm not blaming you btw, we live in paranoia-inducing times and it's wise to check out reasons for caution we may not have thought of ourselves, but if I were the buyer I'd walk away.
Once it was confirmed safe to do so I sent him close up of the back of the headstock but the question of why he wanted it remains.
As previously mentioned, I was the one that walked away but feel free to mention any actual reason you'd ask for the serial number.
The main reason would be that it's a quick and easy way to look up some information on the guitar. It would help me form a better idea of the spec of the guitar, and cross-reference that against the description as part of the whole "does this sound about right" process.
Secondary reason would be that the answer to the question is quite revealing. If the guitar is legit then there shouldn't be any problem giving out the serial number. If the answer isn't a straight forward "here you go" then it would indicate something worth further consideration. Particular if the answer is "no" or "I can't, it's damaged/missing/somesuch". If the answer was "no" without any reason, I'd be fairly wary of continuing, although at that point it would be 50:50 as to whether I thought it was because there was an issue with the guitar, or an issue with the seller being overly paranoid.
Whilst fakes may well have equally fake serial numbers, generally speaking the serial number is going to be a good place to start with validating authenticity. If it doesn't match up, you don't have to waste the journey. If it does, you might go have a look and check things out further etc.
If I were selling then chances are I'd put the serial number in the advert from the off, for the above reasons.
