Not sure yet! But I have a WGS G12Q sat in an empty tweed deluxe cab I can borrow for a while so I'll try that.
I'm intending that to be used for the Tweed ultimately so unless it sounds amazing I'll probably look at something like the Cannabis Rex. I'll probably need the sensitivity of the Crex as although I'm going up in size I'll be losing quite a few DB with the WGS speaker.
Another option might be the WGS C12C/S, which should be much louder than the Q.
Yes, agreed. Really sounds big and bold for a 10". So much so not sure I'll get a massive benefit going up a size. I'm hoping the 12" will help with dispersion but the cab is probably the limiting factor.
Guess that's what Deluxe Reverbs are for.....
Bump.
I’ve put my Jensen back in until I get a baffle sorted for a 12” and suddenly realise how good this speaker is!
