Attaching pedals to a pedal board
OnparOnpar Frets: 424
How do fellow guitarists attach pedals to a pedal board with regards to the rubber feet that are on the pedals?
Are you suppose to remove the rubber feet on the pedals first?
If you don't remove the feet then you are limited in positioning the pedals as you have to accommodate the feet when using velcro on the bottom of the pedal.
  • TateFXTateFX Frets: 114
    Feet off, velcro on :)
    Formerly Stu_Tate
    Tate FX
    www.TateFX.co.uk
    Instagram
  • PablocrackersPablocrackers Frets: 181
    I normally remove them and keep the rubber feet in the box it came with for a flat finish to the board.
  • ecc83ecc83 Frets: 1644
    Once again can I ask?  Don't plaster Velcro over serial and model numbers!
    Dave.
  • NorthernStompsNorthernStomps Frets: 398
    Yep, simple as that!
    Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
    Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
    Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
  • SlimbertSlimbert Frets: 341
    Feet get in the way.
    Keep em safe in the box for when you sell the pedal next week.
