Bizarre Fact of the Day
15678911»
  • Emp_FabEmp_Fab Frets: 24414
    edited June 2018
    Two thirds of the global tiger population are kept as pets in homes in the USA.
  • DopesickDopesick Frets: 1510
    If you manage to balance a Yorkshire pudding on your nose while stirring toilet water with your index finger...you're a disgusting freak and should be beaten up.
  • quarkyquarky Frets: 2777
    Each person in America eats about 46 pizza slices a year.
  • notanonnotanon Frets: 610
    Time flies more slowly the nearer you are to the Earth (or any large mass)  Physicists can actually measure the difference in the flow of time for something 1 foot off the ground compared to something on the ground.
    For example, if one person spent 79 years living at an altitude 1 foot higher than another, the first person would end up approximately 90 billionths of a second older.
    https://www.google.co.uk/amp/s/amp.livescience.com/8672-higher-faster-age.html
  • guitargeek62guitargeek62 Frets: 4156
    Amateurs! I have roughly one pizza every 10 days, usually 8 slices a time, so that puts me at 292 slices a year!
  • proggyproggy Frets: 5835
    When you clean your vacuum cleaner, you actually become a vacuum cleaner.
  • interstellarinterstellar Frets: 486
    no you dont you become a vacuum vacuum cleaner
    Wouldn't you actually become a used-to-be-vacuum-and-will-be-when-you-turn-it-back-on cleaner?
  • munckeemunckee Frets: 12414
    We are so far away from the sun that we cannot feel its warmth directly, the radiation it emits speeds up the particles in our atmosphere and it is the friction from the moving particles which causes the warmth which makes out planet habitable.
  • BellycasterBellycaster Frets: 5863
    There is an Island on this Planet that you cannot go to.
    It's true, I just checked and Ryanair do not fly to there.
    Only a Fool Would Say That.
  • BigBearKrisBigBearKris Frets: 1755
    Nope. You'd become a vacuum cleaner cleaner.
    And the Apprentice of the Vacuum Cleaner Cleaner, who happens to have the better personal hygiene of the two, he would be a Cleaner Vacuum Cleaner Cleaner.
    I’m not entirely sure I believe that.  Do you have any verifiable sources ?
  • valevale Frets: 1052
    if you wanted to make a black hole that contained the same mass as the earth you would have to compress the entire mass of the earth (approx six trillion trillion kgs) into a sphere 16 mm in diameter.
    hofner hussie & hayman harpie. what she said...
    edited June 2018
    for the first few hundred million years of its life following the big bang, the universe was actually a superhot (several thousand degrees) orange plasma soup, fuzzily lit up like halogen lamps light up fog.
    not black & not transparent. just weird.
    Yes Stephen Fry said it on QI once! Doesn't get any more reliable than that : )
  • sweepysweepy Frets: 4190
    QI have gotten things wrong on more than one occasion, I rarely take it as Gospel
    https://dave.uktv.co.uk/top-10s/gallery/top-10-times-they-got-it-wrong-qi/
    To name but 10 ;)
    https://forums.digitalspy.com/discussion/2152859/inaccurate-qi-facts
  • KilgoreKilgore Frets: 8600
    edited June 2018
    The Moon (no atmosphere) gets up to about 100 c in daytime.
  • NiteflyNitefly Frets: 4924
    That's because it's made of green cheese.
