Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
That 3M stuff looks amazing... I'm getting some to try. Thanks guys.
Offset "(Emp) - a little heavy on the hyperbole."
Let's see how this stuff pans out.
Go easy with the Dual Lock, small squares in the corners will be plenty. For pedals I cut it into thirds, lengthways - it's strong.
There's also a 3m double-side gel tape which will add less height if that is a problem.
https://images-na.ssl-images-amazon.com/images/I/71vJMJPcJjL._SL1441_.jpg
That stuff that Guitarist used to use for their cover CDs (as long as you never need to get it off again).
