Hi all, I have my eyes on getting a Variax at some point however I'm torn between which to get. I can't afford a Tyler USA one so it's between the 2 above and I'm looking at used so the price difference isn't so huge. Probably £3-350 for the Standard and around £450-500 for the Tyler.
From what I've read all of the Variax software and tech is the same in both guitars, so it's simply the outward guitar thats different. I've read reviews on the net comparing the standard to Yamaha's Pacifica line (not sure which range it would equal), I've had a budget Pacifica before which was pretty good in its price range, however the Tyler is supposedly the better made instrument. I'm in no position at the moment to try either, however I wnt one initially to try with a view to gigging in the long term. With that in mind I've kind of thought the more expensive one would be best for that but I'm open to anyones experience of both guitars to convince me otherwise!
Thanks in advance, Al
The yard is nothing but a fence, the sun just hurts my eyes...
Very much appreciated, I shall get looking for one near me then. Thanks again
However, you'll need to invest some serious time to learn the models, and which switch activates which model/pup selection as the switches do different things for different models and there's a big list. I did like the ability to instantly alter tunings but if you play quietly at home you'll hear the 'true' EADGBE tuning under the 'modelled' re-tuning which is disconcerting - at any reasonable volume however that shouldn't be a problem. I also liked the ability to programme favourite models and tunings into the toggle switch (JTV59)/slide selector (JTV69).
But the big disappointments for me were the guitar modeling and its 'fiddliness'. With a few exceptions, the models were less than convincing and a lot of the models sounded so similar to each other such that any difference was by and large somewhat inconsequential. The 12 string modeling was actually fairly useable and the Sitar was interesting but I suspect most players wouldn't use the latter much. Perhaps it was a quirk/fault of the one I played, but sometimes it took a few goes for the open tuning to sound right. However, if you plan to use this at a gig you really will need to learn your way around it or just stick to a few models programmed into the toggle/slider selector. Trying to navigate via the main Variax knob would just be a nightmare for most people.
It also felt 'different' to playing the guitar in modeling mode v on-board p/ups. It's hard to explain but there was a certain loss of direct sensitivity/feel where it didn't respond in quite the same way. I don't think it was 'lag' per-se but it just felt a wee bit 'un-natural'.
Hence why you really need to put one through its paces before buying.
To cut to the chase, and although I really wanted to, I just didn't get on with it and ended up buying the Yamaha Pacifica 611VFM.
Cheers!
You therefore seem to be agreeing that at quieter volumes the acoustic 'true tuning' can be heard and can be disconcerting - but I don't then understand the first part of your post (in bold) above?
i have just finished my Ramble on patch which lets me switch from acoustic to electric to harmony delay all with snapshots
The Tyler isn’t a great guitar it’s not bad either it’s just there
I wouldn’t gig with just the Variax but I use it for a few specialist songs.
i think the mags are awful though and would change them if I was going to use it more
(Edit: just checked, indeed it does!)
I still use it quite a bit to play "acoustic" and find it helps to mentally picture the modelled tone you are playing. I certainly play a 335 style guitar differently to a Strat for example.
A year or so ago I asked on here if it was worth getting one and the general consensus was that as the electrics are the same...I would be better off waiting for new models to be released when the electronics would be upgraded as essentially it was 'old technology'. I haven't played the JTV models at all.
Totally agree with this.
Would definitely recommend downloading and reading the Variax Standard Pilots Guide for information on the models...modelled!
https://uk.line6.com/variax-modeling-guitars/resources/
Yes agreed about the 300 model 12 strings, they were something that I rarely bothered to use as they weren't very convincing. I will have to try one of the newer models sometime.
Further down the line can you forsee a new range of models being released?
Like;
https://line6.com/variax-modeling-guitars/variax-hd/
