Strat back plate
  • ICBMICBM Frets: 72828
    I don't have one on mine currently as I can't find one that fits - its not a Fender - but I do find the occasional snagging on my belt buckle annoying, so I'll get around to making one eventually...
    ICBM said:
    clarkefan said:
    Why are the two backplate centre screws offset is the real issue
    To stop you accidentally putting the plate on upside down, which would then make getting the strings through the holes impossible.
    Leo knew musicians quite well :).
    Aha!  30 year personal OCD thing solved, thank you :)
  • axisusaxisus Frets: 28348
    Strat backplates, like Les Paul pickguards, should always be on.
    In the book of life it says only if you tuck your shirt into your underpants and keep the top button done up on your shirt.
  • 57Deluxe57Deluxe Frets: 7348
    No Plate con = chance of catching your pubes in the springs
    <Vintage BOSS Upgrades>
